Will the LT4 HOT cam RR fit under my valve covers?
Old Dec 13, 2002 | 08:16 PM
btheri3's Avatar
I read that the L98 valve covers won't accomodate the 1.6 ratio roller rockers that come in the hot cam package (as in if you want to upgrade a zz4). I was directed (via a magazine) that I should order the billet adapter to allow non-center bolt valve covers to be installed, and get a pair of old-style covers.
What I currently have are the crome GM valve covers (center bolt) with the red bowties on them (12355350).
Just want to know if the LT4 HOT cam roller rockers will fit under them.
Ben T.
Old Dec 13, 2002 | 08:31 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
shouldn't be any rpoblem. all they are is crane rockers. and if these fit under my stock ones, then they should fit.
www.fl-thirdgen.org/rockerswap.html
Attached Thumbnails Will the LT4 HOT cam RR fit under my valve covers?-1.6rockers.jpg
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
blackd-out z28
Aug 15, 2015 08:18 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
