Would like some feed back on 1.6 roller rockers
Old Dec 14, 2002 | 10:54 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I have a 1990 formula with a 305 tbi that I am in the process of converting to tpi. I was wondering if putting on self aligning 1.6 ratio roller rockers will make a noticable difference or should I stick with the factory ones. (yes I know TBI heads are not as good as TPI heads, but that is what I have for now)
Here are the changes I have so far.
Tpi unit, plenum ported.
LT1 Cam
GM LT4 springs, retainers, keys
Old Dec 14, 2002 | 12:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You should definitely get some real rockers, as opposed to the factory rubber ones. Just going from flexible ones with ratios all over the place to ones that transmit the full lobe profile with consisstency from valve to valve, makes all th difference in the world.
There will be essentially no difference whatsoever between 1.5s and 1.6s as long as you keep the other, tighter restriction of those anti-performance TBI heads on there. Even with good heads, there will be little difference. I'd recommend sticking with 1.52s, since if you go up in the ratio, you'd be at risk of pulling out those pull-out rocker studs. Get the Comp 1417-16.
midge54
Dec 27, 2019 04:14 PM
LT1Formula
Aug 20, 2015 09:36 PM
IrocZ'85
Aug 17, 2015 06:24 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
