LT1 questions
Old Dec 14, 2002 | 09:18 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
LT1 questions
In what year did the LT1 get a long pin in the camshaft?
Thanks,
Brady
Old Dec 14, 2002 | 10:12 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: LT1 questions
Thanks,
Brady
I believe all the LT-1/ LT-4/ gen II style motors use this "long pin" camshaft.
Old Dec 14, 2002 | 10:53 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i dont know but someone at www.camaroz28.com will, it's mostly fourth gen guys there.
Old Dec 15, 2002 | 12:07 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i believe it was 95 for the f bodies when the vented opti started.
Old Dec 15, 2002 | 08:30 AM
Vader's Avatar
F-Bird is correct. They all have a somewhat longer pin than the old style SBC engines. The '92-'93 model engines were only slightly longer than the "standard" SBC-Gen I configuration. These cams also had a smaller, tapered hole in the front end of the blank to center the distributor drive. In 1993 (for the 1994 model year), the "long" pin was made even longer, and the distributor drive centering hole was enlarged to accomodate the change in the OptiSpark distributor drive on four-bolt main (Corvette) and iron-headed engines. This change supposedly didn't appear on the 'F' cars until the following year. So I guess the replies are all correct in some respects.
Incidentally, any 256-inch engine from this family has the longer dowel and larger hole, even though it is technically an L99 instead of an LT1.
EDIT: I meant to say "265-inch engine", not "256-inch engine".
Old Dec 15, 2002 | 11:16 PM
zippy's Avatar
Engine: 5.3L
your right vader, i should have pointed out that the b and y body had the vented opti starting in 94 and the f body in 95.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
