Reverse Lights.....Wires from tranny missing!
Old Dec 15, 2002 | 05:01 PM
gruveb's Avatar
Car: 1989 IROC-1
84 Z 28, T 5 tranny.
Backup lights don't work.
Trouble shooting the problem I worked my way to the tranny. There are no wires coming off of the tranny for the switch.
The switch from the tranny has a two pin socket and is located near the front on the driver's side correct?
The wires are no where to be found. At this point in time I am sure I'll have to wire it myself.
That switch provides the ground correct? Before I hack into anything I want to make sure.
Thanks again.
Old Dec 15, 2002 | 06:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is not ground, 12V goes to the switch, and when in reverse, passes through to the bulbs.
The harness has a dark green and a dark blue wire. It breaks out from the main harness right behind the distributor.
Old Dec 15, 2002 | 06:35 PM
gruveb's Avatar
Car: 1989 IROC-1
Thanks again RB. I'll start digging around looking for it.
Old Dec 15, 2002 | 09:42 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
hey make sure you let us know where you find a connector to fit that plug cuz i need to hook up my tail lights too.
Old Dec 16, 2002 | 12:37 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Dude, you can get those anywhere.
BTW, my lights won't stay on either. They flash on and off like a bad connection. I'm going to replace the connector first, then the switch if it still happens.
L98GTA87
Oct 19, 2015 10:43 PM
BLK87Z
Sep 18, 2015 11:29 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
