Picture of 6 3/4" balancer with timing mark?
Old Dec 17, 2002 | 02:59 PM
GilmourD's Avatar
I think the outer ring of my balancer has slipped, making my timing WAY wrong. Does anybody have a good pic of a balancer so I can see where the mark is in relation to the spokes of the inner hub?
Old Dec 17, 2002 | 03:28 PM
flyin89's Avatar
Pull the #1 plug and set the dampner at TDC if its all the way up it should be right. rock it back in forth to confirm TDC of piston.
Old Dec 17, 2002 | 03:31 PM
GilmourD's Avatar
It's an 86 balancer, so shouldn't the timing mark be at 1:00?
Old Dec 17, 2002 | 04:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take a look at the keyway for your reference. You can see it if you pull the damper bolt. The crank key is lined up exactly with the #1 & #2 throw of the crank, and so should be at exactly 1:30 at #1 TDC. Of course the marks should line up at that point.
Old Dec 17, 2002 | 08:34 PM
Vader's Avatar
RB covered it, but I'll elaborate (or confuse the issue even more).
With a stock timing chain cover and stock timing tab, the TDC groove in the outer hub of the balancer is (according to my closest measurement) 7° retarded from the broached keyway in the balancer hub. As RB stated, the Woodruff keyway in the crank is machined at TDC of the #1/2 throw. The location of the OEM timing tab on the cover accounts for the slight retard in the timing groove in the outer hub, since it isn't exactly lined up with the #1 cylinder.
Old Dec 18, 2002 | 12:58 AM
GilmourD's Avatar
Thank you ever so much. That is exactly what I wanted to see... Now I just have to compare my balancer to that, and I'll know if it's off.
midge54
Dec 27, 2019 04:14 PM
InfinityShade
Aug 22, 2015 08:00 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
