CFI to TBI I need some help?
Old Dec 17, 2002 | 10:18 PM
Bennyb8323's Avatar
I just ran into a huge problem. I have an 82 Camaro with a 305 CFI and the motor blew up. So recently i have just bought a 88 Chevy 305 and rebuilt it and everything and the CFI intake will not fit to it. So now i am forced to use the TBI that came with it. So i need some help on how to do this? Thanks.
Old Dec 17, 2002 | 10:48 PM
Vader's Avatar
Benny,
The difference is probably in the center bolts of the intake runner sets, correct? If you really wanted to, you might be able to elongate the center hole in the runner sets to align the bolts with the later style heads.
If you cannot or opt not to do that, you'll need to do a little rewiring of the injector harness to connect your TBI injectors. The real difficulty may be in the calibration of the EPROM, since the flow rates of the CFI injectors may be different than those from the TBI.
You'll probably want to research that a little before you decide which route to take. The rest of the engine management can be adapted to your older ECM/harness, but you may have some incompatibility in the wiring harness connectors from your old style harness and the newer style sensors.
Old Dec 18, 2002 | 12:11 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
This would be a good time to trash the TBI for good and toss a carb on there. But if you don't want to go that route, look into the x-ram. Its an aftermarket CFI intake, although i don't know if those fit 87-up heads.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
