Hydraulic Roller cam Identification
Old Dec 19, 2002 | 11:21 PM
Snake_NTR's Avatar
I bought a cam from a private seller and was told it was a stock 350 TPI cam.. how can i use what appears to be the grind numbers to verify this... a website..??? any help would be great as i dont want to put this in if it turns out to be a stock 305 cam...
the only numbers i can find are on the end of the cam.. it has 714 A at the top.. 1091 at the bottom and the letters MAP along the side... side meaning the side as looking at the rear of the cam.. these must be the grind numbers i would expect.... any ideas on how to identify this came will be very helpful... and i'm assuming this is a GM cam... it also has the blue paint mark near the distributor gear drive...
thanks...
Old Dec 20, 2002 | 07:23 AM
ede's Avatar
ede
i ithnk the quickest and easiest way would be to look at the front of the cam for the sholder the retainer palte rides on.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
