What all would I have to change to put in carbed engine in a 4th gen?
Old Dec 22, 2002 | 10:32 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I am building a 406 and am looking to maybe finding a 93 or 94 v-6 4th gen camaro to put it in. Only thing I can think of being a problem is the HEI distributor. Can I get it under the cowl? I've seen carbed engines in 4th gens in magazines but I think that they used a crank trigger. Anyone have suggestions?
Old Dec 22, 2002 | 11:11 PM
flyin89's Avatar
Motor mounts are in different places on the LT1 it is back further on the passenger side. Hood clearance should be a prob look how low the intake is now add around six inches for carb and air filter (hole in hood may even come close to winshield )...
Old Dec 23, 2002 | 04:29 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
You may run into more problems than distributor clearance. Especially if you live in an area where you have strict emissions standards, and youll be running a carb.
Old Dec 23, 2002 | 04:50 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
lmao, why would you want to put a carb on it... dude your a funny funny guy :sillylol:
Old Dec 23, 2002 | 05:14 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
No emissions in my area and will have a cowl hood. I've seen it done before with a big block and a carb so my 406 should work. I can also fab some different type of motor mount if need be.
BECAUSE I WANT IT THAT WAY!! Is that good enough for you? Don't tell ME I'm silly!
Old Dec 23, 2002 | 05:20 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
flyin89 I noticed that your running a 400 and afr's. Are you running 210's? I would also like to know the rest of your setup. I want to run 10's with some juice.
Old Dec 23, 2002 | 07:00 PM
dans82bird's Avatar
Engine: 302
OH, sorry! I just figured out what your doing.... putting a carb on a 406... I thought you were putting a carb on a LT1 or LS1 motor, so I was like wtf, why is he doing this :]
Old Dec 23, 2002 | 11:29 PM
flyin89's Avatar
Yes AFR 210's TRW flat top forged .030 pistons,power detroit 5.7 rods(stroker clearanced with 7/16 capscrews) Crane hydraulic cam 296-516 SNS with 1.6's, Victor Jr with 850 Holley DP, TCI super street fighter with 3:73's and 28 inch tall slicks. I also run cutouts reasonably quiet on the street. Easy low 10's on the bottle!!!
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
