Quick question about the oil pan...
Old Dec 23, 2002 | 03:39 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If i lift the motor off its mounts a few inches, will the pan clear the pickup on the oil pump when i go to take it off? I dont have any help to pull the engine and trans so id like to keep the whole lot in the car if possible.
Old Dec 23, 2002 | 04:20 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Well....if you undo the motor mounts and the exhaust, I dont see any reason you wouldnt be able to get the motor high enough to slide the pan out.
Old Dec 23, 2002 | 04:44 PM
ede's Avatar
ede
basically yes, you have to get the counter weights in the right location and it'll clear.
Old Dec 23, 2002 | 04:48 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if u like ur distributor make sure ya take the cap off.. might even havta pull it out i forget...
Old Dec 23, 2002 | 05:18 PM
Car: 88 Camaro SC
Engine: SFI'd 350
dont think tahts much of a porblem... spent an 1 1/2 hours taking all the crap off in preperation to pull it but my brother cant make it down to help me so ill just float it off the mounts. Thanx for the replies.
Old Dec 24, 2002 | 12:10 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Put the crank mark at 6 o'clock
Remove dist cap
Remove down pipes from manifolds.
Might have to remove starter (I did)
Remove motor mount through bolts
I also removed trans mount bolt
Raise engine 3.5 inches (2X4 sideways)
I raised mine with a jack and a block of wood under the oil pan.
This worked for me. I had the pan off in 45 minutes.
Good luck
B_Dubya
Aug 26, 2015 05:09 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
