Disarming The Airbag
Old Dec 25, 2002 | 09:19 AM
IROC_Vert's Avatar
Car: Camaro IROC-Z Convertible & Camaro
Transmission: Auto & 6 SPEED
Axle/Gears: 2.73 & 3.42
Okay wasn't 100% sure where to post this question. I want to disarm my airbag. I already removed the yellow/green "security" connector which is attached to the airbag.
So basically all that’s left is the female connecter part of the security connecter and the bag itself. I read that static electricity could still cause the bag to deploy accidentally. What else do I need to do in order to disarm the airbag ?
Thank you
Old Dec 25, 2002 | 10:29 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
if you have the airbag off the car it is disarmed
can it still blow you ask?
if it receives the correct hot and ground, of course
store it upward, facing the sky, where nothing will be damaged in case it does pop
acceptable method for disarming the airbag on the car is to simply remove the air bag fuse
Old Dec 25, 2002 | 03:18 PM
IROC_Vert's Avatar
unfortunatly I need to put the airbag back in place but I want to make sure that can't accidently blow up...is there any way I can make sure it won't even blow ?
Old Dec 25, 2002 | 03:54 PM
well, unless you have EXTREMELY bad luck, just do what i said and it should be ok
Eric-86sc
Feb 25, 2016 09:02 PM
1992Z28!
Nov 19, 2015 07:33 AM
tealman92
Sep 28, 2015 01:43 PM
tattmann
Sep 27, 2015 05:20 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
