Wipers just stopped
Old Dec 25, 2002 | 09:03 PM
JohnS's Avatar
Car: 2004 Nissan 350Z
Engine: 3.5 V6
Transmission: 5 speed auto
Wipers just stopped
I was trying to shoot some washer fluid ,none was coming out,so I guess I pushed a little to hard on the control arm and the wipers stopped in the middle of the windshied,had to lower them manuelly. How hard is it to replace the arm and how much is a new one?Good thing I live in So-Cal,it might not rain again for months,but it needs to get fixed.Thanks
Old Dec 25, 2002 | 11:51 PM
Vader's Avatar
The lever should pull right out of the switch. Be careful as you do this, since the wires for the cruise switch are attached internally and don't have a lot of extra slack.
There is a trim cover over the left side of the column that will also pull off. The wiper switch is right under there. If you're lucky, you just got the switch stuck betweeen low speed and park (the off position) and the lever disengaged from the switch. If you're not so lucky, you may have a broken/failed switch.
Old Dec 25, 2002 | 11:57 PM
JohnS's Avatar
Engine: 3.5 V6
How do I get to the switch,without tearing my steering column apart,I've never changed one of these things.Thanks
Old Dec 26, 2002 | 12:02 AM
JohnS's Avatar
Engine: 3.5 V6
never mind,reread your post ,The wires that go into the column are cruise control?I think I may need to replace them because my cruise control has never worked.Thanks
Old Dec 26, 2002 | 03:11 PM
JohnS's Avatar
Engine: 3.5 V6
Anybody know where I can get this switch besides a junkyard,I hate going to them.GM wants $127,Napa and Kragen don't carry it.
Old Dec 26, 2002 | 03:34 PM
82camaro's Avatar
Car: 82 camaro SC
How is the wiper fuse? Even in the off position, the wipers will return(assuming the wiper motor has power and is functioning). Could also be the wiper motor, the washer pump is part of it. Test to see if the wiper motor is getting power from the switch before you replace the switch--the switch may be ok. In my experience, the wipers stopping mid-wipe is the fuse or motor. When the switch goes bad the wipers won't wipe at all(stopped in the hidden position) or they won't stop wiping.
Old Dec 26, 2002 | 03:42 PM
JohnS's Avatar
Engine: 3.5 V6
Thanks,I'll give the fuse a try now,the motor a pretty cheap,my blinkers and high beams still work,if the switch is bad would they still work?Thanks
Old Dec 26, 2002 | 05:07 PM
Vader's Avatar
HOLY crap! Tell them you only want the switch, not the entire stalk.
Anyway, the wipers are independent of the turm signals and headlamps. They are each on separate circuits with separate feeds and fuses. They don't share a switch - only the lever is common to all three.
Old Jan 4, 2003 | 08:27 PM
JohnS's Avatar
Engine: 3.5 V6
Well I feel like a idiot,I didn't notice the connector on the bottom of the wiper motor came off,it was hidden behind vacumm hoses,I plugged it in and now they're working.Also I was tring to get to the switch and broke some little piece of plastic,now when I turn on my lights all i have are high beams
Old Jan 4, 2003 | 11:27 PM
Vader's Avatar
Ouch! That plastic piece is probably the depressor for the switch mechanism. Replacing that will likely mean removing the steering wheel and upper column bowl. This might give you an idea of the mechanism. You're maybe looking for item #19:
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
Hal87
Sep 26, 2015 09:26 PM
