what cam for a 350
Old Dec 28, 2002 | 02:44 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
what cam for a 350
i have a 350 roller motor, with 305 heads, what would be a good cam with a little lope, that wont exceed the max lift on the heads, and i do plan on matching the valve springs to, also i have a set of magnum 1.52 roller rockers im gonna put on it, thanks
Kevin
oh yeah it has a 700R4 with 2100 stall if you need to know.
Old Dec 28, 2002 | 03:40 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Get the Lt4 hot cam..
Heard a lot of good things about it
dont remember the specs..
Old Dec 28, 2002 | 04:28 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
That has way too much lift for the heads and springs. Stick with an LT1 cam and you'll be doing fine.
Old Dec 28, 2002 | 06:09 AM
ede's Avatar
ede
my limit is i nthe .46 or .475 range for factory pull out studs ,plus that's about the limit on stock spring diameter. while you're changing springs get rid of the factory rotator and retainer and get aftermarket to match your springs.
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theshackle
Aug 22, 2015 06:52 PM
