89 2.8 stalling
Old Dec 30, 2002 | 01:11 PM
Clint3240's Avatar
89 2.8 stalling
my 89 2.8 mpfi automatic firebird stalls. i think its because the rpms are very low when im in gear on the break.... or just in park...it sometimes does it when im shifting into or out of reverse. what can i do? and it dose not matter how lonmg the engine has been running for. i raised the idle and that didnt work, i was thinking its the torque converter, ill disconnect that and see what happens, i hooked up a computer to my car and it ran fine, but once i unpluged it it started to stall again, i took it for a drive with the computer and it had no problems....please help
Old Dec 30, 2002 | 01:43 PM
Vader's Avatar
What is the idle RPM when the engine is fully warmed?
Old Dec 30, 2002 | 01:44 PM
Clint3240's Avatar
about 500-200 it jumps like mad
Old Dec 30, 2002 | 07:34 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
when you plug the scanner into the older systems they tell the IAC to raise idle 1000. if you have a scanner on it what are the iac counts? tps volts, is it missing at idle ? have you cleaned the throttle body , they get coated with build-up and need to be cleaned with a good carb cleaner. is the EGR valve sticking open . there is a mini air filter on the back of the egr solnoid that clogs and with it pluged it will pull the egr open at idle. hope this helps more than confuses .
mike
Old Dec 31, 2002 | 12:01 AM
Clint3240's Avatar
no, it helps and thank you ill look into what you said
Old Dec 31, 2002 | 12:12 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
A really crazy MAF?!
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
usafirebird
Sep 29, 2015 11:58 PM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
