fuel regulator question
Old Dec 30, 2002 | 04:30 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
i'm going to put in a fuel regulator between my electric pusher pump and my carb.. but the regulator does not have a return line on it... how do create a return fuel line feed??
Old Dec 30, 2002 | 05:28 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
don't necessarily need return line. what does the pump put out? or you can get the mallory 4309 regulator. it has a return line feed on the bottom.
http://store.summitracing.com/partdetail.asp?part=7607
Old Dec 30, 2002 | 06:16 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
thats perfect mrr23 thanks
quick question tho just to double check... i can just hook up my holley pusher pump to the regulator then the regulator to the carb and thats it right?? i can ditch the mech pump all togehter?(ofcourse fuel filters)
This is my pump
it says it does not require a pressure regulator??! does that mean i don't even need a regulator ??
Old Dec 30, 2002 | 06:22 PM
mrr23's Avatar
Engine: 360 HSR
97 gph. yeah you won't need the maual pump. and don't need the regualtor. pressure on that pump is preset at 7 psi. it runs 67 gph at 5 psi.
Old Dec 31, 2002 | 01:05 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
sooo in other words, i can run a straight line from the electric pump to the carb?? with just a fuel filter... and it won't flood the engine or break the seals in my carb?? i have the edlebrock 600cfm 4barrel
Old Dec 31, 2002 | 05:51 PM
mrr23's Avatar
Engine: 360 HSR
edelbrock/carter carbs don't like more than 5 psi of pressure. so you can try it first. also, your regulator doesn't need a return line for 2 psi difference.
Old Dec 31, 2002 | 08:30 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Vettetrax,
You seem to be fairly knowledgable here, what do you think about a quadrajet under that 7 psi? I think I'm gonna be runnin my new engine with the carb for a while before I can go TPI, but my block doesn't have the hole for the fuel pump pushrod, so, I need an inexpensive way to get fuel to the carb, on a somewhat temporary basis.
Your advice is appreciated!
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
