What Spark Plug do I need to run?
Old Dec 30, 2002 | 08:01 PM
92camaro's Avatar
I was wondering if someone could recommend a spark plug for my engine. It a 355 with 10.5 compression out of the box trick flow heads and it's carbed. I am running it N/A. I also have a MSD 6AL box. Just wondering what plug would be the best. If you need any more spec just let me know. Thanks
Old Dec 30, 2002 | 10:54 PM
Vader's Avatar
I have several more questions that should help us make an educated guess at the dynamic compression of the engine:
What duration cam? LSA?
What peak RPM?
What is the head chamber volume (cc)?
What type of ignition system are you planning?
Each of the three factors will affect dynamic compression. The last answer will help decide what kind of spark energy will be available.
I would recommend copper cored Champions, of course, but the rest of the information will help determine heat range and gap.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
