rockers for LG4
Old Dec 31, 2002 | 11:28 AM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
rockers for LG4
The coming new year I plan on puting a high flow exhuast on my LG4. Should I use 1.5 or 1.6 long slot rockers? 3/8 or 7/16/? Parts numbers would be helpfull. Probally can't do the job myself because of adjusting I know nothing about. I plan on putting on putting in cam later. Can I get a few horses from rockers change.
mods completed/ K & N filter Dual Air snorkel H.O./ Hypertech coil cap and rotor/ Splitfire sparkplug wires/ DR rods and B hanger/
Old Dec 31, 2002 | 06:16 PM
Damon's Avatar
Chad, if you're still running the original LG-4 cam then you might as well get a little extra lift from 1.6 rockers. You need them for 3/8" rocker studs. Long slots aren't necessary. Your rocker studs are pressed into the heads so they are not replacable with screw-in type unless you pull off the heads and have them reworked (which isn't worth the effort).
One gotcha- the 87 LG-4s used the later-style centerbolt valve cover heads that use self aligning rockers. If you have centerbolt heads you will need self-aligning rockers.
Install is as easy as unbolting the old rockers, dropping on the new ones, and readjusting the valves. There are a number of ways to adjust valves that are easy to do in your driveway. you should try it yourself. If you screw up you'll know it as soon as you try to start it. You really don't stand much chance of actually breaking parts- it'll just not run right. So screwing up doen't mean disaster- pull the covers and try again.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
