Disabling governor(speed limiter)
Old Jan 2, 2003 | 09:04 PM
Bandit5's Avatar
I recently swapped rear ends, and the change in gears in my '90 RS (from 2.73 - 3.70 - 9"). I have been having a hard time getting the right speedo gears to compensate.(just using standard 3.73 to make calculations) It works fine for now, but every time the speedo reads 115, which is actually somewhere near '75-80 to my closest guess. This is a real PITA... how can I disable the governor(speed limiter)?
Old Jan 2, 2003 | 09:57 PM
fanman's Avatar
This should help, https://www.thirdgen.org/newdesign/tech/unlimited.shtml
Old Jan 2, 2003 | 11:14 PM
Bandit5's Avatar
Now, other than putting in an on/off switch to temporarily bypass the governor, is there any way to actually program it to a higher level? Like an unatainable level, i.e. 250-300MPH? Or to just eliminate it alltogether so it no longer needs the VSS?
327IROC85
Sep 23, 2015 12:11 AM
adelane
Sep 9, 2015 08:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
