dirty smoke
Old Jan 5, 2003 | 10:13 PM
icebird_1981's Avatar
dirty smoke
my friend has a v6 camaro and he drives it in the winter when he starts up there is smoke that comes out the exhaust pipe it looks dirty like a brown. is this just from it bein winter and its cold out side?? how do u no whats the normal amout of smoke that should come out in the winter. oh and after driveing it for awhile is the smoke suppost 2 stop???
Old Jan 6, 2003 | 12:57 AM
Vader's Avatar
Ice,
In colder temperatures, the humidity in the air will condense in the exhaust system as it cools. On cold engine start, the moisture begins to evaporate and gets expelled out the exhaust as vapor (white colored). This moisture combined with any smoke from either a rich condition and/or oil smoke from leaking valve stem seals or poorly sealed rings can create some odd colored exhaust combinations. The moisture should get eliminated after about 20 minutes of driving on even the coldest days. After that, only the normal atmospheric moisture that is in the intake air gets pushed out the exhaust, so the color should change as the water vapor diminishes. Usually, at much below 0°F, water vapor is evident any time the engine is running, but as diminished levels compared to the start up moisture. And it isn't quite that cold in Toronto right now.
FormulasOnly
Jul 23, 2018 08:47 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
