Pulling the LT1 out
Old Jan 6, 2003 | 10:23 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Pulling the LT1 out
this isn't about a thirdgen but is thirdgen related since some people put LT1's in their thirdgen's . ok i'm gonna be pulling the LT1 out of my 94' Formy. i'm gonna be taking it out from the top and not the bottom of the car. where can i attach the chain(s) to so i can safely remove the engine. the heads? will the support the weight? i just a little paranoid when it comes to this damn engine. i don't wanna screw anything else up. can anyone give some tips? thanks.
Old Jan 6, 2003 | 11:00 AM
Damon's Avatar
Using the intake manifold bolts (one per head, opposite ends of the engine) will hold the weight just fine. My main problem with aluminun heads happens when I bolt the eyelet or chain to the head and then it twist around when weight is put on it- digging a nice divot into the intake mating surface. Just make sure it can't squirm around and work against the head. Don't try to use a rocker stud to lift an engine. Also, there are often bolt holes on the fronts and backs of most chevy heads that make ideal places to screw a bolt into and lift against (although getting to the back of the LT-1 while in the Formula is going to be challenging).
83 Crossfire TA
Jan 3, 2016 01:26 PM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
