timing question est connector
Old Jan 7, 2003 | 12:14 AM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
I own a 88 trans am 305 TBI and Every so often when i started the car it would run really low on the rpm. so i decide to reset the timing. I read you have to unplug the est wire. so i thought i was doing that but i was unpluging a different wire. Its a single wire right above the heter core mini radiator right on the fire wall passenger side. My question is when i do the timing again, do I unplug that wire as well as the est wire( i just figured out where it is yesterday) or just unplug the est wire.
Let me know all of you f-body experts out there!!
the wire in question was causeing it to be the problem because when i started it up and it ran normal i unplugged it and it went into the wierd running situation
__________________
Bill Kaleta
Old Jan 7, 2003 | 12:43 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
You only want to disconnect the EST. It's a single tan wire with a black stripe. Your underhood emissions label should say how to set timing.
Old Jan 7, 2003 | 12:53 AM
TransAmTBI's Avatar
Engine: 305 TBI
i know how to set everything i'm just not sure which wire is right based on the book I have and other opinions. but I'll check to see which wire has the tan w/black stripe
thanx
Old Jan 7, 2003 | 07:47 AM
Vader's Avatar
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
