ATTENTION YALL! TPI TO CARB questions
Old Jan 7, 2003 | 01:18 PM
MadCatX's Avatar
Ok first off
Im not rich
I couldnt afford to keep the Malfunctioning TPI together so i pulled it
I got a new
edelbrock 650 4barrell
edelbrock high rise alum, intake
new HEI distributer
New Carter inline elect pump
heres the deal
ripped the tpi off
and over time and aggravation purchased the above parts
now the car is timed out, ready to roll but it only runs for 4-10 mins and then idles down and dies...the reason
the carter pump still runs and lets the pressure flow back down into the gas tank like its losing its prime
now the intank pump is still in and is un pugged so its not running..do any of you guys know if that pump has asome sort of lock out on it or something...this problem is hell and this is my daily driver..or was its been dead for a month now
oh the Inline pump is mounted under the hood. in line and pulling like its suppose to..the holley burned out when we mounted it under the car...any way any thoughts would be nice
and..I know TPIs are hell but theyre only hell when they work and when you have the loot to fix them..and i dont have it lol
Old Jan 7, 2003 | 01:46 PM
Guest
Guest
Posts: n/a
People have had problems trying to pull through the stock intank pump. I would suggest removing it and replacing the assembly with one from a carbed car.
Old Jan 7, 2003 | 02:43 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
You could also ditch the Carter in-line and buy a Mallory three port regulator and use the stock in-tank pump.
Old Jan 7, 2003 | 03:36 PM
Jza's Avatar
Jza
Generally in-line pumps should be mounted as close to the tank as possible. They push a lot better than they pull.
MustangBeater20
Oct 29, 2022 09:20 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
