car running cold
Old Feb 2, 2002 | 12:56 AM
LincolnHawk's Avatar
car running cold
I went for a drive tonite..hwy speeds for about 25 min straight..and my temp gauge was basically at the bottom...like if had been sitting overnight not running..in the morning i let in run for ten minutes to warm it up and about a minute or 2 after driving the temp drops low..what is cauiseing this and is it bad for my engine?
Old Feb 2, 2002 | 04:00 AM
Jza's Avatar
Jza
Don't be so trusting that the stock gauge is giving you an accurate reading.
With that said, if you're getting normal readings while idling but it drops back down while driving, it's possible your thermostat is stuck open, allowing the radiator to cool the coolant without restriction, and in this cool weather, it can do that pretty efficiently. Does your heater work? It's not the end of the world, but it's still not good for the motor.
Old Feb 2, 2002 | 08:02 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Sounds like your due for a thermostat replacement. There is a way to check the accuracy of your gauge, i found mine reads about 20* hotter then where the sensor is. i used a laser/infared head gun to determin this.
As far as the engine goes, an engine is built with tolerances made to come into the right place when the motor is warm. So running it cold really isnt too good for it.
Steve
Old Feb 2, 2002 | 02:54 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
running an engine cold and hard will cause warping of the block eventually so you should get that fixed asap.
Old Feb 2, 2002 | 03:28 PM
thanks for the replies..what do i ask for at the autozone..thermosat sensor?and wher is it located to install thanks
Old Feb 2, 2002 | 04:06 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
dude, just ask for a thermastat for a 1985(?) Chevy Camaro with a tbi 5.0 and theyll tell you what temps they have, get a 180 or a 190 and get a new seal for it, its like $7 or something, installing it is easy, you should get a chiltons car care manual while your there, its well worth it
Old Jan 7, 2003 | 12:14 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
the thermostat housing is on the front of the engine, get a 180 stat and a new gasket around $6 total also pick up a gallon of anti freeze while you are there, because you will loose some when you change the stat
Old Jan 7, 2003 | 03:53 PM
Jza's Avatar
Jza
I'm pret-ty sure he's got it figured out by now, a year later...
Old Jan 7, 2003 | 04:43 PM
Vader's Avatar
You think?
Old Jan 7, 2003 | 05:02 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
my mistake i didn't notice the date sorry
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
