URGENT! truck stuck at work. HELP!
Old Jan 8, 2003 | 08:34 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
i just got a 86 F250 as my winter beater. 351W w/4bbl, automatic. the problem is, when i started it after work, it started and idled fine. i put it into gear, let off the brake, and it started moving while idling but it died every time i even touched the gas pedal. it would start accelerating, but stumble and miss a lot. if i let off the gas, it would be fine until i pressed it again. it completely dies if yu give it more than 1/4 throttle. does anyone have any ideas? i need to get this truck going, because my trans am is off the road til spring!
Old Jan 8, 2003 | 09:08 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
Have you checked or replaced the fuel filter???
Old Jan 9, 2003 | 08:36 AM
Vader's Avatar
After checking the fuel filter, clean the choke linkages, set the choke position and high idle RPM.
Bubbajones_ya
Oct 25, 2015 08:01 PM
tmellott89
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
