Dropping computer...still need 02 sensor?
Old Jan 9, 2003 | 08:05 PM
BillZ28's Avatar
Car: 84 Z28
I was just wondering for when I pick out headers. All the computers are coming off and a Holley is going on.
Old Jan 9, 2003 | 08:43 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
newp
Old Jan 9, 2003 | 09:12 PM
restoIROC's Avatar
Car: 2000 Monte Carlo SS
Engine: 3.8 V-6
well?
Well what about the electric fuel pump? Does it get effected by going to a carb from TPI? Doesn't the computer control fuel and timing?
Hmmm...
Old Jan 10, 2003 | 04:34 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
I have no computer system on my car. I still have the oxygen scensor, but it just plugs the hole, the wire has been cut off. You do not need it. You could use a bolt or somethin to plug the hole.
Old Jan 10, 2003 | 06:40 AM
89RsPower!'s Avatar
yeah, u'll need to wire the pump so that it comes on with the key in the run position and your going to need to put a fuel pressure regulator in and regulate it down to about 8 psi or so
Old Jan 10, 2003 | 07:58 AM
restoIROC's Avatar
Engine: 3.8 V-6
so...
So....the ignition would stay HEI and a person could just put a mechanical fuel pump on? I was thinking about doing that to my IROC 305TPI but.....I want to keep the car somewhat original. The more cube engines go into other cars. The LB9 screams anyways- Thanks again guys-
Ben
Old Jan 10, 2003 | 01:24 PM
89RsPower!'s Avatar
yes you could convert to a mechanical pump but simply wiring the electric pump to run in the run position and regulate the pressure down is easier considering you already have the electric pump in the tank
Old Jan 10, 2003 | 02:33 PM
Vader's Avatar
And you'll get spark, but no timing advance unless you change to a mechanical distributor like the '74-'80 Chevys.
Old Jan 10, 2003 | 04:04 PM
restoIROC's Avatar
Engine: 3.8 V-6
fuel
So would the electric fuel pump in the gas tank be in a closed position when it is off? If I were swapping to a 69 400ci motor, could I just remove the LB9 and hook the fuel line to a mechanical fuel pump? Boy, it seems like a lot of trouble to go through to swap to a carb motor, right?
I am full of questions-
Ben
Old Jan 10, 2003 | 04:23 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Interesting question Ben!
I have a 1977 350 running with a mechanical fuel pump, with the electric one still in the tank. The mechanical pump pulls the fuel through the electric one in my case and runs okay. I even ran the pump up once or twice (fuel line disconnected) to get it into different places when it stopped and it still pulled fuel through.
I have heard of this happening in some cases but not all.
Suck it and see (if you will pardon the pun!).
Andy.
Old Jan 10, 2003 | 04:59 PM
89RsPower!'s Avatar
he mentioned that already.. hei although technically a hei module is electric and not mechanical like an old points dist im not sure if a mech pump would work with a electric one in the tank still or not.. intresting though.. still i'd just use the electric if i knew in good working order
Old Jan 10, 2003 | 06:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yes, spark is electronically done, but advance and curve are mechanical.
Note to Vader, please clarify all wording in the future
Old Jan 10, 2003 | 07:11 PM
89RsPower!'s Avatar
lol! haha sorry not tryin to be a dick i was just pointin out that the dist issue was already mentioned.. good point tho i guess it is techincally mechanical.. no offense to vader.. ur 1 of the more helpful people on here when it comes to a difficult question :hail:
Old Jan 11, 2003 | 08:00 AM
Vader's Avatar
No prob. I just didn't see in Bill's post the part about switching the distributor. I still don't...
Old Jan 11, 2003 | 11:07 AM
restoIROC's Avatar
Engine: 3.8 V-6
thanks
thanks Andy BTW-my bro lives in London, great place.
Anywho......so I understand that using a mechanical fuel pump on a thirdgen TPI-to-carb motor swap would work but.....
I am still a little confused on if the distributor would be affected by the computer removal and if any modifications would need to be done?
Ben
Old Jan 11, 2003 | 11:48 AM
BillZ28's Avatar
Car: 84 Z28
http://5finger.8m.com/tpi2carb/tpi2carb.html
Old Jan 11, 2003 | 08:18 PM
89RsPower!'s Avatar
there ya go.. the dist would be effected dramatically.. you would still have spark but no timing advance without the computer
Old Jan 13, 2003 | 06:23 PM
restoIROC's Avatar
Engine: 3.8 V-6
Great link Bill!
I have it figured out now, thanks for all the help guys-
LAter, Ben:hail:
Old Jan 13, 2003 | 06:42 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
why go to carb? if i wunan dirve it everyday and still get decent gas milage i woudl stick with tpi, i went from tbi to carb and its the worst move i ever made, i am gonan get a smaller cam and a tpi setup
92firebirdguy
Sep 1, 2016 07:53 AM
corey8084
Sep 17, 2015 02:56 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Eric-86sc
Sep 7, 2015 02:10 PM
