Roller lifter/engine assembly question...
Old Jan 11, 2003 | 02:01 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I have a new set of Comp roller lifters. They say not to wait too long before engine start-up after you install them. I assume this is because the oil will run off the roller and it will be dry on start-up.
Is there anything else I can use (like lithium grease) on the roller? I'm still fabricating my valve cover and my A/C compressor relocation bracket. It would be great if I could get the engine together now. I'm just sittin around waiting for the valve cover to come back from the welding shop.
Old Jan 11, 2003 | 04:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's because the oil in the chamber will all leak out, and they will clatter at startup for a little while.
Other than that, it's no big deal.
I usually just use motor oil on roller cams for build-up lube.
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
