ticking sound
Old Jan 13, 2003 | 12:35 AM
gm hombre's Avatar
Car: 1989 WS6 GTA
ticking sound
i have this problem,when i start the car,(5.7L gta) i here this ticking comming from in between the engine and tranny,when it idles you can here it ticking,when i start to drive it, it goes away,but when i come to a stop, it begins again,i have checked to see where it could be hitting but i don't see it hitting nothing,and it can't be hiting the starter so what do you guys think?GM HOMBRE.
Old Jan 13, 2003 | 01:20 AM
lane's Avatar
Cracked flex plate? Maybe????
Old Jan 13, 2003 | 03:01 AM
radiateu2's Avatar
ticking sound
???collapsing lifter, exhaust leak, loose flex plate/fly wheel, bad throw out bearing is it auto or man transmission?
Old Jan 13, 2003 | 09:35 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i had the same thing happen to my old 350 after the rebuild i did. i never put new rings in it and they were worn so much that the actual piston itself would slap the cylinder walls and did exactly what u were stating. my dad said they call it piston slap. i didnt know so i took his advice since he was a mechaninc for 11 years. i would start looking towards a collasped lifter in the back of the block before tearing it down to find out its not piston slap. search the easier fixes first to save u money and headaches
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
