Running problem when cold.
Old Jan 13, 2003 | 09:16 PM
iroc420's Avatar
Does the cold start injector have anything to do with the engine after it runs?? I notice after my car sits over night in the cold weather of NY it run's funny. The idle bounce's and is low.if I rev the car a few times it seem to fix it self. Also it will stall untill the cars run's maybe about a min. though maybe head or intake gasket but I haven't noticed any lose of coolant. Could it be the IAC?? I replaced the coolant temp sensor. And have check the TPS. What do you guys think. Could it be an O2 sensor??
Old Jan 14, 2003 | 07:49 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I'm no expert on the TPI system, but the ECM shouldn't be looking at the O2 sensor until the engine has warmed up a bit more than what you describe.
I think cleaning the IAC and throttle body out would be a good start, if it's gummed up the cold idle can be affected.
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
mustangman65_79
Aug 8, 2015 12:07 PM
