Stubborn bolts on air injection system.
Old Jan 15, 2003 | 12:33 PM
Joeboy's Avatar
Im trying to remove the air injection system from my car. I have the driver side completley off. It took a long time but I finally got the bolts off. The passenger side is being really stubborn though.The flange bolts into the exhaust manifold wont budge. They just round. I was thinking of either penetrating oil. or if that doesnt work maybe cutting off the tubing and getting a socket on it. Anyone have suggestiongs?
Old Jan 15, 2003 | 03:33 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: Stubborn bolts on air injection system.
Originally posted by Joeboy
...maybe cutting off the tubing and getting a socket on it. Anyone have suggestiongs?
That's EXACTLY what I did. I had no plans to ever put that stuff back on, so out came the hacksaw
If there's any sort of grip left on the heads of the fittings, try giving them a little nudge to tighten them, then loosen them. IIRC, they're brass (soft metal) and should easily come out once the 'rusty seal' to the cast iron has been broken. This should give you a head start on breaking them loose.
Old Jan 15, 2003 | 03:34 PM
AJ_92RS's Avatar
Oh yea...
If you can be VERY CAREFUL, you can start the car and let it run for a wee bit. The heat will also help them break free.
If you're smart you'll wear thick leather gloves.
Old Jan 15, 2003 | 04:27 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
I don't know if the last post was necessarily good advice - mine softened up when the car was warmed up and they rounded - made it almost impossible to get them out.
Old Jan 15, 2003 | 05:18 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Get a smoke wrench on it...if you have access to one.
Old Jan 15, 2003 | 08:51 PM
jamesbob02's Avatar
Car: 92 Z28
Trying not to show my lack of knowledge here, but what's a smoke wrench?
Old Jan 15, 2003 | 09:38 PM
AJ_92RS's Avatar
Propane torch
AKA... heat wrench, hot wrench, and FIRE!!!!!
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Fast355
Dec 2, 2016 06:33 PM
toronto formula
Nov 10, 2015 06:17 AM
bryan623
Aug 10, 2015 11:33 AM
