need help with error codes.
Old Jan 16, 2003 | 07:25 PM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
when i checked my check engine light out today, it gave me error code 34 which is "34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)" can anybody tell me what jacked up and how to fix it please?? any help would be greatly appreciated, thanks
Old Jan 16, 2003 | 07:52 PM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
someone please help me.....
Old Jan 16, 2003 | 09:49 PM
Vader's Avatar
Luvr,
It would help to know what year/engine/fuel system you have, since the codes vary somwhat between the different systems. A '34', for example can be a MAP sensor on a TBI engine or a MAF sensor on a TPI or MPFI engine.
The diagnosis would be slightly different for each type.
Old Jan 17, 2003 | 07:54 AM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
the car is an 82 TA and the engine is an AC Delco stock replacement engine that was put in, in 99. its a 305 (not HO) with a 4bbl.
Old Jan 17, 2003 | 11:03 AM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
anybody?.?.?
Old Jan 17, 2003 | 02:41 PM
Vader's Avatar
Luvr,
Scan again for error codes and make sure it is a '34'. If so, check the BARO sensor mounted to the firewall. Make sure the electrical connector is clean and tight. There is no vacuum line to the sensor on an '82 IIRC, so all you can do is test teh circuit. You can test the sensor with a handheld vacuum pump or manifold vacuum supply in the same manner that you would test a MAP sensor, but I believe the output is scaled differently.
Falcon50
Aug 22, 2020 03:26 PM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
BWilcox
Sep 20, 2015 12:19 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
