Is it the Cam making me stall?
Old Jan 16, 2003 | 09:45 PM
snisbet375's Avatar
Car: 1983 camaro z-28
Engine: 305 crossfire
Just put a big cam from a dirt track car into a 350 street car. It idels fine until i put it in gear. Then it just stalls. If you give it a little gas its fine. And man it sounds great.
Is the cam to big?
Could it be something else?
Old Jan 17, 2003 | 02:59 PM
Vader's Avatar
Snis,
Do you have an idea about the lift/duration/overlap specs of the cam? If you have a lot of overlap, idle vacuum can be very low. Also, depending on the timing of the cam, idle and low RPM power can be affected. Did you degree the cam when you installed it?
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Fronzizzle
Aug 9, 2015 01:15 PM
