Cylinder head porting pictures for AFR195
Old Jan 18, 2003 | 09:23 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Thought you guys might want to see my ongoing tests of the Air Flow Research AFR195's. I bought a set, and I'm doing extensive flow testing as I go about modifying them myself.
I'm pretty impressed on how well these heads flow, and it surprises me how hard it is to find additional air flow. However, I've increased air flow a couple percent without seriously increasing port volume.
Anyway, FWIW, here's the page, complete with a spreadsheet of flow data:
http://www.ws6transam.org/afrheads.htm
I'm not done yet! My goal is an ideal 75% I/E flow ratio, with a airflow that exceeds AFR's "street-port" advertised flow numbers.
Cheers,
Daniel Burk
Old Jan 19, 2003 | 03:18 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Nice job of documenting your project ! What are your plans for
a rear end that will live behind that monster motor ?
Old Jan 22, 2003 | 03:29 PM
ws6transam's Avatar
Two words:
Slippery tires!
Naw, seriously, I installed a heavy duty Gleason Torsen differential, Richmond gears, and Moser 28-spline axles into the rear-end. Coupled with a T/A stud girdle, the rear should hold up to most everything but the hardest launches. I'll keep away from slicks. If I start seeing 1.6 second 60-foot times, I will buy the Moser 12-bolt. However, I will probably nurse along the 10-bolt by sticking to Drag Radials and keeping away from nitrous. There's a lot of 10-bolt equipped eleven second rides out there...
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
