Compression ratio guess
Old Jan 19, 2003 | 08:12 AM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
The compression in my 388 right now is 9.9:1 with 60 cc aluminum heads. I'm planning on putting a supercharger on and at the same time want to get better heads like the AFR 195's. I'm hoping to kill two birds here because the AFR's come with 68 or 74 cc domes. What do you think the compression would be at with the 68cc heads and what would it be at with the 74cc heads? I'm hoping to get right around 9.0:1.
Old Jan 19, 2003 | 10:45 AM
Vader's Avatar
Greg,
There is a lot more than the head volume in the calculations for static compression ratio. Check this file: Engine Calculations.xls Just download the spreadsheet and enter your data, It should get you close. It doesn't take into considertaion the head gasket volume from a diameter perspective, but I'm working on that one. If you are using head gaskets with no extra bore clearance, it will be right on the money.
Old Jan 19, 2003 | 12:19 PM
Damon's Avatar
Greg- I can calculate anything from anything if you are ABSOLUTELY CERTAIN that your beginning compression ratio is really 9.9:1.
IF it is really 9.9:1 to begin with AND your reads really are 60cc AND you resuse the same type head gaskets you have now then switching to different sized combustion chambers will yield the following compression:
64cc = 9.54:1
72cc = 8.86:1
74cc = 8.71:1
Old Jan 19, 2003 | 07:51 PM
boogie's Avatar
....and a 68cc would give you 9.1:1
Old Jan 20, 2003 | 04:49 PM
Greg's Avatar
That's exactly what I needed thanks a million!
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
