Why is it knocking?????
Old Jan 19, 2003 | 07:26 PM
Ghigman3's Avatar
Car: '87 IROC-Z
Engine: Modded 305 TPI
Ok I have an LG4 w/ 700r4 tranny. While in open loop it knocks real easy when I hit the gas and when I am in closed loop it still knocks when I hit the gas but not as bad. could it be a bad knock sensor? The timing is at 6* and I'm out of ideas.
Old Jan 19, 2003 | 10:09 PM
MdFormula350's Avatar
yeah could be the knock sensor..
Old Jan 20, 2003 | 12:27 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Shouldnt the base timing on an LG4 be 0* ATDC?
Old Jan 20, 2003 | 12:50 AM
Ghigman3's Avatar
Car: '87 IROC-Z
I'm not sure I know that it was set at 0* but it still gave a ping in the same conditions just not as bad so maybe it is but I don't have anything that tells me what it should be so any help would be nice.
Old Jan 20, 2003 | 01:14 AM
Raiden's Avatar
A vacume test and a compression test can tell you alot! Also, how doyour plugs look? Any oil in the water or visa versa?
could it be bad fuel? just a few thoughts.
Old Jan 20, 2003 | 08:04 AM
Ghigman3's Avatar
Car: '87 IROC-Z
plugs are only a year old and the car hasn't even been driven for a year. I've tried going to a higher grade of fuel but that didn't help.
Old Jan 20, 2003 | 10:26 AM
Vader's Avatar
Ghig,
You can test the EST when setting the base timing. If the timing advances after the bypass is connected (or ALDL jumper is removed) the EST is at least functioning. Check the detonation (or knock) sensor (KS) to see if it is still connected. Inspect the connection to see if it is clean and not corroded. You could remove the sensor and test it as well.
Another thing I've seen is that the KS will get "muted" somewhat by the accumulation of rust and debris in the cooling system. The sensor is installed in what was once intended to be a drain plug hole at the lowest part of the case, and rust, mud, and debris tends to accumulate there. You might want to remove the KS and see if there is a lot of contamination there. If the cooling system has not been flushed and maintained regularly, this is a good possibility. The layer of soft, wet rust and junk can mask some of the signal to the sensor, even though it is screwed directly into the casting.
Old Jan 20, 2003 | 11:49 AM
Ghigman3's Avatar
Car: '87 IROC-Z
Ok I'll give it a try and get back to you later today.
Old Jan 20, 2003 | 04:36 PM
Ghigman3's Avatar
Car: '87 IROC-Z
Ok I set the timing to 0* and replaced the knock sensor and that helped alot. it still has a little ping just before the transmission shifts under hard acceleration though.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
