these were connected to???
Old Jan 20, 2003 | 02:05 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
I removed the ac crap from under the hood today and noticed these spots where some thing was apparently connected. what would that have been? and is the car ok with out it? also can I safely remove the top highlighted hose from where it is connected to the firewall?
Attached Thumbnails these were connected to???-photo1-6-20-02
Old Jan 20, 2003 | 02:55 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Those look like either the Heater core lines or 1 of them is the Transmission cooler line.
Old Jan 20, 2003 | 03:03 PM
Makaveli's Avatar
is that silver can looking thing that you took out that i see in so many cars able to be removed if you take out AC but leave in heat? whats it called anyway?
Old Jan 20, 2003 | 03:12 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Makeveli
I've always heard that the silver can is called a dryer. If it is left open to the elements very long, it loses its drying capability. I think it suck any free moisture out of the the freon. I'm not an expert on that but that is the way it was explained to me.
Old Jan 20, 2003 | 03:13 PM
rezinn's Avatar
The silver can is the accumulator, yes you can remove it if you take out the a/c. The two lower spots look like the a/c used to connect there and one is a port for the high pressure side. The top one I don't know. You may want to check your smog system since the diverter valve is in that area.
Old Jan 20, 2003 | 03:16 PM
Car: 91 Camaro RS
Engine: 305 LO3
heater core is a good possability for the top hose. it had rust in it so that would make sence. as far as I can tell the trany cooler line is still connected. there is a smaller diamiter metal tube that runs up from behind the engine and goes into the radiator.
to my knoledge(some one please correct me if Im worng) that can is where the R-12/R-134a goes. any way as far as I know it has nothing to do with the heater. but keep in mind the defrost wont work quite right with out the ac.
for me it doesnt matter eather way, my heater and ac nether one worked. the system will blow air threw the vents still so it does some what work when I need defrost to help clear rhe window.
Old Jan 20, 2003 | 03:21 PM
Car: 91 Camaro RS
Engine: 305 LO3
I dont think the lower tubes went to the ac. all tubing for the ac system was connected, and in my car at least the high and low ports are on the accumulator(BTW thanx for saying what that can was. I honestly had no idea its name)
Old Jan 20, 2003 | 03:23 PM
Car: 1991 RS
Dragon-
The steel tube looks to have been cut off. Mine runs along the frame rail.
The back connects to one of the two heater core stubs.
The front connects to the radiator.
In the middle there is a "T" (I don't see yours) that goes straight up and connectos to the vacuum operated valve that controls the coolant flow.
If picture attaches, it is the black heater hose running parallel to my forearm.
S-D
Sorry for the poor photo, I was using it to remember how wires were routed, but happened to have it available.
Old Jan 20, 2003 | 03:34 PM
Car: 91 Camaro RS
Engine: 305 LO3
Thanx swerve-driver after reading your post(and looking at the pic) Im guessing the heater core went out on the previous owner and rather than replace it they just gutted part of the heating system.
which makes sence now. the hose that comes off the rad goes into the back of the engine and Im guessing that is originaly the hose that went to the heater core.
InfernalVortex
Apr 20, 2021 11:31 AM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
