distributer firing order
Old Jan 20, 2003 | 07:18 PM
1987chery z's Avatar
any one know how to figure out my firing order for my distributer??.....i forgot to number them before unplugging my spark plug wires..it has the firing order on the book but thats not all i need to do...i know.. that was a rookie move..please help.
suggestions and ideas are greatly appreciated.
Old Jan 20, 2003 | 07:41 PM
llvll4l2c91350's Avatar
If you look at the distributor cap from above, of the two terminals facing the front of the car, the #1 terminal will be the one on the driver's side. The order is 1-8-4-3-6-5-7-2,,,going clockwise.
Old Jan 20, 2003 | 08:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
#1 can be anywhere on the distributor.
Pull the #1 spark plug. Plug the hole with a thumb or back end of a screwdriver. Bump the engine over until #1 is at TDC. The compressed air will try to push out. Check the timing mark to be sure. Pull the distributor cap off and see where the rotor is pointing. That's where the #1 plug should be on the cap.
Old Jan 20, 2003 | 08:36 PM
Yeah true. If the distributor was pulled before #1 could've been left at a different position.
Old Jan 21, 2003 | 08:36 AM
Vader's Avatar
KCG
Jun 24, 2020 04:33 AM
db057
Apr 28, 2019 07:45 AM
drptop70ss
Oct 4, 2015 09:44 PM
camarohelp
Sep 22, 2015 03:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
