350 Cam
Old Jan 21, 2003 | 12:20 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
350 Cam
roller cam, Duration @ .050" 214/220, Lift .452"/.465", Lobe sep. 109',
would this be a good choice for a 350, with ported 305 heads, edelbrock performer intake, 600-750 cfm carb, 700R4 trans, 3.42 rear gears, also the cam will get springs that match, the car will be daily driven also.
The cam is a take off out of a crate motor, i can get it for 80 bucks so what do you think of it?
Old Jan 21, 2003 | 12:27 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Will make a nice streetable daily driver. The LSA is a bit tight but fine for a carb.
Old Jan 21, 2003 | 05:19 PM
STIFFLER's Avatar
that cam sounds like a Crane cam 2032 except they are 112 LSA
sure its not that?
Old Jan 21, 2003 | 09:19 PM
Engine: 383, L69
how would this thing idle?
Old Jan 21, 2003 | 09:33 PM
Engine: 305-4v
It should be quite liveable. The duration is acceptable, the lift isn't outrageous but the LSA is a little narrow. Still, with a carb it will be good.
The narrower the LSA, the rougher the idle due to intake/exaust valve overlap and the resultant lower vaccum at lower rpms. But it also helps mid-range torque.
The notorious peanut cam has a 109 LSA, too. But, as Apeiron told me, it has no vacuum issues because it never opens the valves :lala:
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theshackle
Aug 22, 2015 06:52 PM
