where is this leaking from?
Old Jan 21, 2003 | 02:17 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
k no 3rd gen.. my nova has a nice puddle of oil under it after sitting for about a month its a 350 with a th350.. the oil is dripping off of the passanger side of the bellhousing but it is oil and not tranny fluid... where could it be leaking from? im thinking since its been sitting for so long anything up higher wouldnt make any sense.. so maybe rear main? what are other possiblities?
Old Jan 21, 2003 | 02:45 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Most likely the valve cover gaskets..cheap fix. Or the intake gasket..exspesive fix...Probably one of the two. But you say it has sat for a month but leaks from the top..that is weird, or it just took a while to fall to the ground.. It may be the rear main seal, but I doubt it. HTH.
Old Jan 21, 2003 | 03:05 PM
89RsPower!'s Avatar
nm i stopped being lazy and went out in the cold to look at it... its not oil its really dirty tranny fluid.. its black hehe.. crack in the torque converter
Old Jan 21, 2003 | 09:15 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
