my car has wheel shake!?!?!?!
Old Jan 22, 2003 | 03:18 AM
crawlin 25th's Avatar
Car: 92 z28
Engine: carb'd small block
Transmission: th400
Axle/Gears: 10+2 bolt
when i drive my car it has very bad wheel shake when i hit a bump.....heres what i think might have an effect on it..ok i switched my motor over to carbereuted and didnt put the power steering pump back on it... changed the springs struts and shocks.... and i havent had an alignment so i dunno if that could be it......also i have the stock rack and pinion on it still and by not having the pump on there would it make my car have wheel shake?????? please if anyone could help i would be very thankful.....
Old Jan 22, 2003 | 12:23 PM
Car: 92 z28
Transmission: th400
can anyone help????
Old Jan 22, 2003 | 05:24 PM
aklaim's Avatar
Two things:
1. You dont have a "rack and pinion" setup. No third gens do unless its a custom job.
2. You have either destroyed or are in the process of destroying your gear box. It needs lubrication, which the power steering pump provided. Hook that thing back up. The amount of power your losing by actualy using it is minimal. If you want to go to manual steering then go find a s-10 box and do the swap. Your not saving any weight by not using the power steering pump. The s-10 box will shed some pounds from your car though.
Old Jan 22, 2003 | 05:44 PM
Damon's Avatar
Either one of the shocks is totally blown out or you left something loose in the steering linkage. Even if the box was a totally worn out POS it wouldn't have violent wheel shake. Deactivating the P/S won't have any effect on any of this- it just makes the sheel harder to turn. Something's gotten loose on you.
Old Jan 22, 2003 | 11:22 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Shake
Just went thru this with a '91 Z Make sure your idler arm is tight (no movement). I changed it and still had the shake, then I noticed the mouting holes are slotted so I loosened the bolts pushed the arm all the way up and tightened the bolts. The shake went away.
HTH,
Don>>>
BlueIroc-Z
Jun 9, 2019 03:22 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
