LT1 cam
Old Jan 23, 2003 | 11:22 AM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
LT1 cam
would an lt1 cam be a direct swap into my car? What would I need to do it. And would I be better of with a comp cams 262xe or the lt1? Assuming im getting head work done in the future.
Old Jan 23, 2003 | 12:59 PM
Vader's Avatar
That's like comparing "apples" to "fruit". Which LT1 cam are you asking about? There were at least six factory grinds.
And "head work" is a little ambiguous. Do you plan only port matching, bowl porting, larger valves, porting and valves, chamber work, milling?
If you are planning to go with larger valves and ports, a little less lift can accomplish the same end. Granted, the 305 is more limited on valve size selection, so you might have to get all your flow with porting and a cam profile. In that case, the LT1 grinds are probably going to be disappointing.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
masonta
Sep 1, 2015 06:40 PM
