Trying to fix these 3 problems.... (They were error codes I got)
Old Jan 24, 2003 | 01:09 PM
GoldenSwordZ28's Avatar
Ok, just to see what in the hell was going on with my car today, I decided to go out and check with a Diagnostic Tool *cough* Paper Clip..... And I got the following error codes.
13 - Oxygen Sensor Signal Problem Or Loss
14 - Coolant Sensor - High Temperature Fault
21 - TPS Voltage To High
What kind of problems would this be causeing? And how can I fix um? I mean, what should I do to fix them? Hopefully someone can help me here, cause I'm a bit lost on whats going on
Adam
Old Jan 24, 2003 | 01:21 PM
rezinn's Avatar
From those codes I'd think you'd have a bad idle, bad gas mileage, and the car could be stalling sometimes. Do a search to see what to do. I'd start by checking all the connections to those three sensors, resetting the tps, and if the others have never been changed, replace them. I'll reply again after I get back from class.
Old Jan 24, 2003 | 01:25 PM
Morley's Avatar
Were these codes just stored codes or was the ck eng light on when running?
For the O2, check that the wiring is intact, if it is..replace sensor.
For the Coolant temp sensor, if the coolant temp is in the normal range check the resistance of the sensor. If not ok replace sensor
For the TPS, check and reset voltage as required. If it can't be set properly, replace it.
Attached Thumbnails Trying to fix these 3 problems.... (They were error codes I got)-ctsmat.gif
Old Jan 24, 2003 | 01:28 PM
rezinn, everything you said right there..... describes exactly the problems I have.
Morley, those were stored.... the check engine light is always one when I'm driving though.
How do I check all of those? Like the TPS and what not...
Adam
Old Jan 24, 2003 | 02:01 PM
Morley's Avatar
To check the TPS voltage you'll need a digital volt meter and either a jumper for the connector or some pins to pierce the insulation (I don't like this method)
With the key on, engine off check the voltage on pins A&B on the connector (Blue and black maybe?) the reading should be .50-.60 volts.
Old Jan 24, 2003 | 02:54 PM
What does all that control? I mean, whats the voltage in the TPS sensor have control over? Oh, and, do you have a pic of the TPS? And where I need to stick the voltmeter and jumper (What do you mean by jumper?) I have a voltmeter, but, what exactly do I do with it, and where do I stick that, and what about the jumper?
Just tryin ta figure out how ta do this
Thanks man
Adam
Old Jan 24, 2003 | 04:35 PM
Vader's Avatar
Throttle Minimum Air Position
Tools needed:
1. Torx driver # T-20
2. Paper Clip
3. Small Punch
4. Tachometer
GENERAL NOTE: The engine should be at normal operating temperature before performing any adjustments. Never rely on the dash mounted instruments for diagnostics and adjustments. The oil pressure and temperature gauges and the voltmeter and tachometer just aren't calibrated accurately enough for diagnosis, but are a relative indication for monitoring the vehicle while driving.
For this adjustment, the transmission will be in DRIVE while you're under the hood. You will need to securely set the parking brake and block the drive wheels. It would also be a good idea to have an assistant hold the service brake while you perform the adjustments.
In order to successfully complete the adjustment, the IAC air passages and pintle need to be clean. The throttle plates and bores need to be clean as well. If this is not the case, you'll need to remove the air cleaner from TBI engines or the intake air bellows from TPI engines to gain access to the area to be cleaned. A spray-type carburetor cleaner works well for this. Cleaning the IAC passages on a TPI/MAF engine will set a DTC, but we'll be clearing that later. With the engine idling, direct the spray cleaner in to the IAC air passages and around the throttle plates. Shut off the engine and continue cleaning the throttle plates by opening the throttle manually. Once everything is satisfactorily cleaned, replace the air bellows on TPI engines. Many times, this alone can solve IAC/idle speed problems.
If this doesn't solve the problem, you may need to remove and clean the IAC stepper motor. If the IAC appears to be clean and functioning properly, continue with the adjustment procedure.
Idle Air Control Cleaning
You can remove the IAC and service it. Remove the electrical connector from the IAC. Unscrew the IAC unit from the throttle body.
You can gently rock the pintle back and forth and allow the spring to extend it until it comes apart in your hands. Clean everything with lint-free cloths and a mild solvent. Harsh solvents can affect the insulation of the stepper motor coils. It's generally the dirt and buildup on this worm shaft that causes sluggish IAC operation.
When the worm gear on the pintle shaft is clean and dry, apply one drop of clean light oil to the shaft and work the pintle back into the rack gears of the motor by the same rocking motion. It takes a while to get the pintle back into the worm gears, but you'll get it. It is important to get the pintle fully retracted into the housing so that the pintle is not forced against the gears when reinstalling the IAC unit in the throttle body.
While the IAC is out, clean the air passages in the throttle body. The orifice in the TB where the IAC resides is the seat that the IAC valve closes against, and it can accumulate a lot of carbon, dirt, and debris. The easy way to do this is with carburetor cleaner and a small stiff brush.
When everything is clean and dry, replace the gasket if it is damaged, apply a little anti-seize to the threads, and torque the IAC to the proper specs. (13 ft/lb for '85-'89 , 30 in/lb for 1990-on.) Proceed with setting the TPS and minimum air position.
Locate the ALDL connector under your dash panel, in the driver's footwell area. Remove the plastic trim cover (if it is still there).
Cut and form a paper clip into a "U" shape. Insert the clip ends into the ALDL in the 'A' and 'B' sockets.
Turn on the ignition, but don't start the engine. This will force the ECM into its diagnostic mode. Wait 30 seconds to allow the IAC pintle to fully extend. Under the hood, remove the electrical connector from the IAC, then turn off the ignition and remove the paper clip jumper from the ALDL. With the IAC pintle fully extended (closed) all idle air will be controlled by the position of the throttle plates. Some manuals indicate that the EST bypass connector should be disconnected for this procedure, while some make no mention of it. While timing is a factor in idle speed, the EST should only operate as a function of engine RPM, temperature, and detonation sensor inputs. To remove all doubt, disconnect the EST bypass connector is your car is so equipped. Some TBI and V-6 engines do not have this bypass connector, and therefore must be set with no regard to the EST system. The EST can be bypassed on some cars by grounding the diagnostic terminal at the ALDL and continuing with the procedure, but the fuel mixture will be skewed to the rich side, affecting idle speed as well. In any event, the minimum air position idle speed range is wide enough to allow for some variations. As always, it is best to consult your service manual for the exact procedure for your system.
Locate the Torx screw on the left side of the throttle body. It may be equipped with a protective metal cap from the factory. This was intended to discourage adjustment. If the cap is present, use a small punch to knock it out. Once the screw is accessible, start the engine and place the transmission in DRIVE. Adjust the throttle stop to obtain 400 RPM with the transmission in "DRIVE" on an automatic transmission car, 450 in neutral on a manual transmission car, rotating the Torx screw clockwise to raise speed and counter-clockwise to lower speed. Once the idle RPM is set, place the transmission in PARK and turn off the engine.
Re-connect the electrical connector onto the IAC. Start engine. Idle speed should be governed by the ECM at approximately 600-650 rpm in "DRIVE" (for unmodified cars). Idle speed in NEUTRAL or PARK is less significant, and will be higher.
Throttle Position Sensor (TPS)
Tools needed:
1. Digital Volt-Ohm-Meter (VOM)
2. Breakout jumper wires or probes (make your own)
3. AutoXray, Diacom, or similar scanner will replace the VOM and jumper wires.
Turn on ignition, but don't start the engine.
With a diagnostic scanner: plug in the scanner and read the TPS voltage. It should be 0.54Volts +/- 0.07 VDC.
Connect the VOM to the TPS electrical connector terminals ‘A' and ‘B'.
With a breakout jumper: Disconnect the electrical connector from the TPS. Install the breakout in-line, between the TPS and wiring harness connector. Connect the meter probes to terminals 'A' and 'B' on the connector. (‘B' is the positive connection, ‘A' the signal ground, or negative.)
With probes: If you have very slender probes on your VOM, you can back-probe the TPS connector while it is attached to the TPS. If you have made probes of large dressmakers pins or a similar item, you can back-probe the connector as well. Connect the meter probes to terminals 'A' and 'B' on the connector.
Turn on the ignition to read the TPS output voltage at the idle position. The reading should be 0.54VDC +/- 0.07VDC. The ideal is the center of the range, 0.54VDC for a stock engine. To adjust the output voltage, loosen the two Torx screws holding the TPS to the throttle body, and slightly rotate the TPS up or down, reading the voltage until it comes into specification. Tighten screws. Using the throttle lever, rotate the throttle to WOT (wide open throttle). The TPS voltage should be over 4.0 volts. Close the throttle again, and then slowly open it to WOT, observing the voltage reading. It should increase progressively and in a linear fashion. If it sticks or jumps or falls off at all while doing this check, the TPS sensor may be failing and could be a cause of stumbling and driveability problems.
After achieving the desired setting, turn off the ignition switch. Remove all jumpers or the scanner and reconnect the TPS connector as required.
Reinitializing the ECM
If you set a DTC during the procedure, the SES light should be illuminated on the dash. This ECM retains DTC data for the previous 50 engine starts, so the codes will eventually be cleared. If you want more immediate results, after shutting down the engine disconnect the negative battery terminal for five minutes. This will clear the ECM of all diagnostic trouble codes. Clearing the ECM also clears any data learned about your engine, and clears the radio presets. If you have a Delco-Loc or Theft Loc II radio, make sure you follow the procedure to unlock the radio protection before disconnecting the battery. This five minutes is also just about long enough to clean both battery cables. Reconnect the battery. When you first start the engine after clearing the ECM, the engine will operate with base parameters programmed into the ECM PROM. These parameters may not be optimum for your engine, but the ECM will enter a Block Learn Mode soon after the engine is warm and enters Closed Loop Mode. The ECM will write new data tables specific to your engine and will eventually rely on those tables instead of the base tables of the factory program. You can expedite this process by driving the car for 20 minutes under varying conditions to allow the ECM to initialize. Or you can wait and drive the car normally at your convenience. The BLM tables are constantly being updated as sensor input ranges change, but the greatest change will occur within the first twenty minutes of Closed Loop operation.
Old Jan 24, 2003 | 05:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Carb or FI?
Just replace the O2 sensor and CTS, it's as much trouble futaing around with testing them as it is to just swap them. High coolant temp code usually = shorted CTS wire; if your car still has the original sort of coaxial-looking CTS connector, just replace it anyway, because it has long since fallen to pieces, and the parts of the connector are touching. The newer style has 2 small opins and looks like a mini Weatherpack connector. Much better.
The TPS is inside the carb. It's a bit more of a challenge. Requires opening up the carb. There's a driven-in plug sealing its adjustment.
Best thing to do is clear all the codes, then drive it until the light comes on, then stop and read it, then track down the problem and fix it. Repeat this until the light quits coming on.
If multiple codes are stored like that, it's kind of stupid to start just swapping parts based on them. The computer is "smart" enough to attempt to correlate sensor inputs and see if they make sense; for example, low MAP (high vacuum), high TPS (throttle wide open) and low RPM all at the same time, is a condition taht can't possibly exist. So, which code will it set??? If it sets the low MAP code but the problem is really a broken TPS, you'll be chasing your tail all day trying to replace the MAP sensor to fix it, because that isn't what's really wrong. The computer won't tell you what part is actually broken necessarily, only that from what it sees, there's something wrong with that reading.
Old Jan 24, 2003 | 05:33 PM
Its a carbed car engine. Thanks for all that info Vader, and RBL
Adam
Old Jan 24, 2003 | 08:18 PM
Morley's Avatar
Vader, you HAVE to have that already typed up and stored somewhere.
Old Jan 25, 2003 | 09:32 AM
Vader's Avatar
GS,
With a carbed engine, the procedure is a little different, but the idea is the same.
FLOAT CHECK
  1. Remove the air cleaner and cap any vacuum lines that were disconnected;
  2. Unplug the Throttle Position Sensor and enrichment solenoid connectors;
  3. Remove the choke pull-off actuator and linkage rod (25 & 28);
  4. Remove the secondary metering rod cam follower (10) and metering rods (9);
  5. Remove the choke lever screw and lever, and the linkage rod (29, 30, & 31);
  6. Remove the air horn screws (5, 6, & 7) and the two front carburetor to intake bolts;
  7. Carefully lift the air horn (1) off the carburetor body. As you do, pivot the air horn to allow the accelerator pump linkage rod to be removed from the top lever (3, 69);
  8. Hold down the float hinge pin (57) and simultaneously hold the front end of the float (56) closed against the inlet needle and seat (55), to raise the float to its maximum position. Verify correct float level by measuring the rear edge of the float to the top of the carburetor body with no gasket in place. Gently bend the float tab to raise or lower this setting to the specification;
  9. Replace the gasket and reassemble the carburetor, being careful to properly align the metering rods, pickup tubes, and TPS actuator plunger;
  10. Reconnect the hoses and electrical connectors;
TPS ADJUSTMENT
  1. Start engine and allow it to reach normal operating temperature;
  2. Set engine timing at the specified RPM;
  3. Set base idle speed with the A/C off and idle speed solenoid disconnected;
  4. Turn off the engine;
  5. Insert the probes of a digital voltmeter in terminals ‘B' and ‘C' on the TPS connector (center and bottom terminals). You may have to insert a paper clip or similar object into the rear of the connector to make contact;
  6. Turn on the ignition but do not start the engine. Read the voltage of the TPS. Remove the top plug (19) and adjust the TPS screw (18) to obtain a reading of 0.48VDC across the terminals.
    NOTE - If your meter probes are reversed, the reading will be -0.48VDC. The important factor is the number.
  7. Replace the hole plug in the adjustment screw hole when the position is set;
  8. Connect a dwell meter or oscilloscope probe to terminal ‘B' on the enrichment solenoid connector;
  9. Start the engine and allow it to reach normal operating temperature. Start the engine and reset the base idle if necessary. The dwell meter reading should vary while this is occurring, or the oscilloscope square wave frequency (pulse length) should vary;
  10. Set the parking brake, block the drive wheels, and place the transmission in DRIVE for an automatic car, NEUTRAL for a manual car;
  11. The dwell meter reading should fluctuate between 10° and 50° on the 6 cylinder scale, the oscilloscope should indicate a 15-85% duty cycle. Adjust the idle air bleed valve screw (12) in 1/8th turn increments to obtain a dwell reading between 25°-35°. The optimum setting is 30° (50% duty cycle), so get as close to this as possible. Adjust the screw only a little at a time and allow the system to react between adjustments;
  12. If the desired reading is not attainable through this method, the idle mixture screws will have to be adjusted (87). This will require removal of the carburetor and cutting the throttle body away around the steel plugs. Then reinstall and adjust the idle mixture screws evenly , then adjusting the idle air bleed screw as described above to obtain the correct readings.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
