KB pistons & stroker
Old Jan 24, 2003 | 03:37 PM
tpi_roc's Avatar
Anybody here use KB pistons (kb135 specifically) in a stroker?
Anybody run into any balance pad clearancing issues with them?
Old Jan 24, 2003 | 10:28 PM
boogie's Avatar
I have used that very piston on a set of reconditioned stock 5.7 rods and 3.75 stroke crank with no balance pad clearance problem.
Old Jan 24, 2003 | 10:31 PM
tpi_roc's Avatar
Damn must be the crank then
Im running an eagle 4340 2 piece and the first counter weights' hit'n the #1 piston balance pad, pretty strong too
its the 5700 crank (specifically for 5.7 rods)
I was concerned with the rod botls, they cleared, too bad the piston dont
Old Jan 24, 2003 | 10:37 PM
boogie's Avatar
I used a two piece seal Scat cast steel crank.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
JSDaddy189
Sep 26, 2015 03:50 PM
