Question about vibration damper
I have the damper out to replace the oil seal. So far everything's going without problems. I have a question though. I noticed that the damper has about a half inch thick amout of RTV at the end of that guide slot. I'm guessing someone previously put the RTV in the slot and then installed it, to make sure there were no leaks. Would this dry silicone cause a vibration at all that could be felt inside the car?? Probably not but I'm wondering cuz my motor has had this slight vibration starting at about 2500 RPM and I have no idea what it could be so I just thought I'd ask. Thanks.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
theres nothing in a stock one to leak, unless its an aftermarket fluidampner ?
end slot ? you mean the keyway for the crankspline ?
Yes, that keyway. And I have the stock damper with the rubber in it. Apparently before installing someone put RTV in the slot. I have no idea why. Like I said my guess would be to just be sure it doesn't leak. But would this lil bit of dry silicone cause a slight vibration?
Engine: 4.3L Z TBI
no and theres nothing really there to leak unless somehow maybe oil traveling length of the keyway ?? but still... i woulnt worry about it, just reinstall it unless its damaged
