Lucas Oil --- Good or Bad?
Old Jan 26, 2003 | 09:51 PM
Laymaster's Avatar
I posted this on camaroz28.com but I figured people here could lend a hand, as well as it being good reading..
Keep in mind I have a '95 LT1, but how oil performs should be similar...
Normally people see "additives" as bad things, at least people with some knowledge. Examples such as fuel injector cleaner or engine oil stop leak....
Anyway....anyone ever see Lucas Oil? You can use that stuff in rear ends or crankcases, so it says. Anyone ever use it? I used a half quart in my last oil change, and I recently changed my oil (to pure mobil 1 again) and I noticed that without hte lucas oil the car ran much better at cold temps. I do have a quart of lucas oil in my rear end...anyone think I should dump it?
Old Jan 26, 2003 | 10:09 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
on bottle it states not to be used with synthetic oils. not a good thing to do. i'm not sure what you mean runs better at cold temps w/o it? as for the quality of the lucas additive, it's pretty good. it quiteted a knocking noise on start-up.
Old Jan 26, 2003 | 10:14 PM
breathment's Avatar
i am gonna guess Lucas Oil is just a bottle of synthetic oil of some sort. like maybe a super concentrated mixture or something..
Old Jan 27, 2003 | 12:33 AM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
I use Lucas Motor Oil Stabilizer in my car. I don't notice a difference like you do. Its not really meant for HP. I know it does its job though. I just say its better to use it than go without. I don't know about the whole synthetic thing. The bottle says it blends with ATF, Mineral oil, and Synthetic.
Old Jan 27, 2003 | 01:09 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I always saw Lucas as just a thick oil. Thick oil will make your car run kinda bad until it warms up when you're in a cold climate like jersey.
Hell, my beretta has a little bit of a problem with 10w-30 in the winter. I go to 5w-30 and no more problem.
Old Jan 27, 2003 | 03:50 PM
Open_Slot's Avatar
Dude, I changed my oil this morning from 5w-20 to 10w-30 and I thought I forgot some pieces. Man I used to always run 10w-30 but I went a long time before changing(so it was good and black and smelly). Then I changed to 5w-20 and couldn't really feel a difference, until I added Z-Max. When I added Z-Max I really gained about 30-40hp(Z-Max is a steel lube that goes in your oil and gas). Well, I changed my oil this morning thinking it would run smoother. Wrong, when I moved back up to 10w-30 it ran like crap(real bad lean spot after it comes off idle, real sluggish now). I'm thinking about adding some tranny fluid to raise the viscosity a bit.
Old Jan 27, 2003 | 04:15 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Can't say anything about the Lucas oil, but I can say I put half a bottle of Lucas Slip Fix in the transmission (it's shifting hard but not missing any gears) and it cushioned all of the shifts a tad...not a whole lot, but can't expect too much from half a bottle.. Point is, I couldfeel it!
bryan623
Mar 22, 2021 06:43 PM
89GTAOz
May 16, 2020 09:31 AM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
