Bigger Rockers, how much more lift?
Old Jan 28, 2003 | 10:03 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
Gross Lift Int./Exh.
.452
.465
I will get that number with 1.5 rockers and now i have 1.52 so what will be the lift now?
Old Jan 28, 2003 | 11:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
gross lift divided by old rockers times new rockers
.452 / 1.50 x 1.52 = .458
.465 / 1.50 x 1.52 = .471
Aftermarket rockers are very accurate. The 1.52 would by +/- .005.
Factory stamped steel rockers rated at 1.50 could be anywhere between 1.45 and 1.55
Old Jan 28, 2003 | 11:33 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yeah 1.5 rockers are actually supposed to be 1.52.
Old Jan 29, 2003 | 02:46 PM
white91Z28's Avatar
Engine: TPI 350
Thanks thats what i needed to know.
Old Jan 29, 2003 | 08:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
A more accurate way is to get the cam lobe specs. If the lobe spec says .300 then that times the rocker ratio is the exact lift.
.300 x 1.52 = .456
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Jorlain
Oct 8, 2015 01:57 AM
sjorgens
Oct 1, 2015 07:54 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
