Is a Flat Tappet Lifter... all the same?
Old Jan 29, 2003 | 11:03 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I'm going to buy the Comp Cams XE268H-14 and the Cam doesn't come with lifers. The motor I have now has brand new flat tappet lifters from a "GM 300 horse Cam." So I was wondering if I needed to buy the specific new Comp Cams Lifters... or use the ones I've got now.
Old Jan 29, 2003 | 11:07 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You can run them if they haven't been run before.
Old Jan 30, 2003 | 01:49 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
IIRC, the "XE" means it's one of their Xtreme Energy cams, correct?
Those cams have a very aggresive cam profile, and CompCams recommends that you use their lifters because of it (as well as their valve springs).
I don't know what the diff could be, other than the shape of the lifter face. Maybe they're lighter? Maybe they have a different "pump up" rate? I dunno, but if I was spending the money for that cam, I'd make sure I called them and ask them. The worse that can happen is they'd say "No".
1-800-999-0853
Old Jan 30, 2003 | 05:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The last XE cam I had, came from Comp with Sealed Power lifters.
I don't know who GM buys theirs from; but as long as they're new, and all the usual procedures are followed for break-in, they should be fine. Of course, if something wipes out, Comp may well decline to warranty it; it's your own risk.
Old Jan 30, 2003 | 12:57 PM
Good Call. I havn't priced the cam directly from Comp... but Summit wants $120 for just the cam and then $90 for the lifters. The springs I have should be fine, they are going to be the upgraded vortec heads.
Thanks for the phone number... I'll definatly give them a call.
PurelyPMD
May 5, 2016 04:57 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
BLK87Z
Sep 18, 2015 11:29 PM
