Serpentine belt AC compressor problem
Old Jan 30, 2003 | 09:03 AM
arshielav's Avatar
Hi,
I have an 89 iroc with a newer 350 crate motor. The air compressor has siezed-up 3 times in 6 months. Added refrigerant helped once but not now. It is locked tight.
Want to leave on but somehow gut so it spins free. That way I can leave the same size Serpentine belt in place. Wouldn't have to fool around with the belt tensioner (it would be in wrong place without the ac unit).
Any suggestions or ideas on what to do?
Old Jan 30, 2003 | 09:06 AM
ede's Avatar
ede
replace the compressor, or the clutch
Old Jan 30, 2003 | 10:34 AM
arshielav's Avatar
Have replaced compressor twice plus added refrigerant once.
Old Jan 30, 2003 | 11:01 AM
Vader's Avatar
Did you happen to add any refrigerant oil either of those times?
Old Jan 30, 2003 | 12:24 PM
arshielav's Avatar
Yes. Bought can with first trade in. Now would like to run without but can't figure out best way.Trying to leave same set-up and just have the compressor free-wheel, any suggestions?
Old Jan 30, 2003 | 01:30 PM
rezinn's Avatar
You can get an a/c delete pulley cheaper than a new compressor. Try a search.
Old Feb 9, 2003 | 03:24 AM
arshielav's Avatar
Rezinn,
Thanks for your time and advice. Bought delete pulley and it works perfect. , t.r.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
