Proper pistons
Old Feb 1, 2003 | 08:46 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Proper pistons
Can you use 5.7 pistons on 6.0 rods. Now with standard deck the math figures out the piston would pop up .003". Can I use a thicker gasket or can I have the pistons cut. I am just wondering because I found a great deal on a set of pistons but I have 6.0 rods. Thanks.
Old Feb 1, 2003 | 09:42 PM
Vader's Avatar
Tim,
A +.003 deck height is not a significant problem with the right gaskets. As always, you'll want to check valve clearances, and of course you'll have to watch any ridge issues with the rings. I suppose you could cut the tops, but that's so little it wouldn't be worth the setup.
265" L99s used longer rods from the factory, but they adjusted the piston pin bosses accordingly.
Old Feb 1, 2003 | 10:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looks like you guys are both victims of the Dancing Decimal Point
The difference in length between 6.0" and 5.7" rods is .300", not .030". So they would stick out of the top of the block about .275" or so with a block of typical stock deck height, not .005". I don't think they make head gaskets thick enough to hide that.
Old Feb 2, 2003 | 06:48 AM
ede's Avatar
ede
i'm glad i'm not the only one here that makes silly mistakes.
Old Feb 2, 2003 | 05:39 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Glad somebody caught that. And the funny part is I have a college degree LOL. Ok now have anohter question. I am having problems with detonation and broken rings, again. I have about 10.2:1 comp with fuel injection and alum heads. But the cranking compression is 220psi, which seems high. Does this seem high? and are those 2 independent of each other or would a high cranking compression cause detonation?
Old Feb 2, 2003 | 07:07 PM
StangKiller's Avatar
220 seems high, but I have seen it before, cranking compression has a lot to do with what cam your running, you need to post more engine details and maybe someone can help you better.
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
FormulaEngland
Sep 30, 2015 01:50 PM
dusterbd
Sep 29, 2015 08:40 AM
wstephan96
Sep 25, 2015 04:28 PM
