Heater Control Function
Old Feb 3, 2003 | 01:11 AM
Buck268's Avatar
I pulled the heater control unit out of my old camaro (now my brothers) because the heater fan would not come on, and basically it didnt work at all (never worked right). Anyways, I found something interesting out, appearently when the temp slider is positioned all the way to "cool" it activated (or deactivates?) some vacuum routing. Does anyone know what this does? I suspect it opens some vent so the cabin is vented even when the heaters (or A/C) is off, though I cannot say for sure. Thanks!
Old Feb 3, 2003 | 07:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It goes to the heater control valve.... opens or closes the coolant flow through the heater core
If the fan won't come on, check the brown wire that leads away from the unit and plugs into the main dash harness. It supplies power to the control head. There is a connector of extremely stupid design that's probably burnt to ashes. Replace the connector with some LARGE insulated slide terminals, it will probably fix it. There's probably nothing wrong with the control head.
Old Feb 3, 2003 | 07:16 AM
Buck268's Avatar
Naw, problem is 2 fold. The Vacuum thingy that connects to the main selector (vent, defrost, floor...) is very busted, and the Electronic multiposition switch connected to the same selector is melted... New parts on the way, though I am unsure if they are the correct parts!
If they are incorrect, no biggy, AutoZone will refund money (they couldnt tell me for sure when I ordered), and I guess I'll be heading to some Junkyards (hey, maybe I'll find the driver side window control module for my Vic too!)...
wigmobile
Feb 26, 2025 02:56 PM
Bubbajones_ya
Jul 6, 2024 08:32 PM
Formula8r89
Sep 22, 2015 04:24 PM
dimented24x7
Sep 17, 2015 06:58 AM
dbrochard
Sep 7, 2015 09:41 AM
