forged vs hyper.
Car: 1988 IROC
Engine: See Signature
Transmission: B&M 700r4
forged vs hyper.
What what would be the advantage of forged pistons, what is hte advantage of hyper pistons, what are the downfalls of each?
what scenario would an engine have to have forged pistons?
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
the way i differentiate between the two is that forged will take alot more abuse. the hypers can only withstand a little excessive heat/hotter spark as well as nitrous and forged can basically handle everything.
if you have a power adder you need forged. hypers are lighter than most common forged and have higher tensel strength but are also more brittle. hypers usually if not always require larger end gaps in the rings, so you'll be file fitting the rings with hypers. hypers tend to be cheaper.
Car: 1988 IROC
I am completely redoing the engine here, and i got all the top half picked out, now i am just deciding on the bottom half.... I am going with a holley stealth ram intake, pro lightning heads 200cc 64cc, and a comp cams cam with 224/224 durat .525/.525 lift 110 lobe sep
do you all think i should go with forged, or hypers?
if i do get any power adder ever, it will only be a100 shot of NOS, maybe 150
LT1Formula
Oct 8, 2015 08:34 PM
roysatikas
Sep 22, 2015 08:15 PM
Andrew Prakash
Sep 8, 2015 11:48 AM
