How much would a 3500 stall Torque Convertor Help my Car?
Old Feb 3, 2003 | 06:29 PM
92camaro's Avatar
I am would like to know how much you think a 3500 stall would help my car out. The engine specs are a 350 with 10.5 compression. Trick Flow 23 degree head, Victor Jr intake. Speed Demon 750. The cam is a Comp Cam. Maguam 292. Not sure about cars weight but should be around 3350. I have a Turbo 400 trans with a convertor that stall about 2500. I have 3.73 gears. Thanks for the help. Also how much to you think a set of 1 3/4 long tube headers would help this car out. I have a set of Hooker 1 5/8 shorty header right now. Thanks again
Old Feb 3, 2003 | 06:46 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If you have high traction tires that can put the power to the ground you can expect 3 to 4 tenths of a sec improvement.
Old Feb 3, 2003 | 06:59 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yeah i would say you'd see a pretty good increase.
Old Feb 3, 2003 | 11:15 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Just by looking at the cam specs in a mag, you are just entering the powerband with the 2500, so the 3500 will help. The LTs will help out also. But it's hard to say the amount of increase of either mods.
Old Feb 4, 2003 | 12:19 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I would recommend it with that HP setup.
84z96L31vortec
Aug 20, 2017 12:16 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
jharrison5
Aug 19, 2015 05:53 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
